BQ24773 IC
JUAN GRAFIX
Moderator
VIP MEMBER
1 Features
1• Host-controlled NVDC-1 1S-4S Battery Charge
Controller with 4.5-24 V Input Range
– Support SMBus (bq24770) and I2C (bq24773)
– System Instant-on Operation with no Battery or
Deeply Discharged Battery
– Supplement Mode with Synchronous BATFET
Control when Adaptor is fully loaded
• Ultra Fast Input Current DPM at 100 μs
• Ultra Low Quiescent Current of 600 μA and High
PFM Light Load Efficiency >80% at 20 mA Load
to Meet Energy Star and ErP Lot6.
• High Accuracy Power / Current Monitor for CPU
Throttling
– Comprehensive PROCHOT Profile
– Input and Battery Current Monitor (IADP/IBAT)
– System Power Monitor (PMON)
• Programmable Input Current Limit, Charge
Voltage, Charge Current and Minimum System
Voltage Regulation
– ±0.5% Charge Voltage (16 mV/step)
– ±2% Input/charge Current (64 mA/step)
– ±2% 40x Input / 16x Discharge / 20x Charge
Current Monitor
• Support Battery LEARN Function
• High Integration
– NMOS ACFET and RBFET Driver
– PMOS battery FET Gate Driver
– Internal Loop Compensation
– Independent Comparator
– Automatic Trickle Charge to Wake up Gas
Gauge
• 600kHz to 1.2MHz Programmable Switching
Frequency
2 Applications
• Ultrabook, Notebook, Detachable, and Tablet PC
• Handheld Terminal
• Industrial, Medical, Portable Equipment
3 Description
The bq2477x is high-efficiency, synchronous, NVDC-
1 battery charge controllers, offering low component
count for space-constraint, multi-chemistry battery
charging applications.
The power path management allows the system to be
regulated at battery voltage but does not drop below
system minimum voltage (programmable). With this
feature, the system keeps operating even when the
battery is completely discharged or removed. The
power path management allows the battery to provide
supplement current to the system to keep the input
supply from being overloaded.
The bq2477x provides drivers and power path
management for N-channel ACFET and reverse
blocking FET. The devices provides driver to control
NVDC operation of external P-channel battery FET. It
also drives high-side and low-side MOSFETs of the
switching regulator.
The bq2477x monitors adapter current (IADP),
battery charge/discharge current (IBAT) and system
power (PMON). The flexibly programmed PROCHOT
output goes directly to CPU for throttle back when
  • bq24773.pdf
