Internet booster
drox-PH-Ceb
Moderator
Staff member
Certified Technician
internet booster inside batch cmd ::refreshing ipconfig ipconfig /release ipconfig /renew ::Flushes and resets the DNS Resolver Cache ipconfig /flushdns ::This command will set your TCP receive window to Normal from the disabled or restricted state. ::The TCP receive window is one of the key factors in the internet download speed. :: Thus making the TCP receive window to ‘Normal’ will surely help you in increasing your internet speed. Netsh int tcp set global autotuninglevel=normal ::this is to boost internet connection Netsh interface tcp show heuristics netsh interface tcp set heuristics disabled ::This simply adds a rule in your firewall ::that will prevent your ISP from throttling your connection while streaming. if not exist firewall_added.txt netsh advfirewall firewall add rule name="StopThrottling" dir=in action=block remoteip=173.194.55.0/24,206.111.0.0/16 enable=yes >firewall_added.txt ::test internet speed start
ping -t 192.168.1.1 setup link :
just install and run setup password: drox
