solved Marvel GSM Tool v7.4 free tool
Bigboydino
Moderator
VIP MEMBER
Marvel GSM Tool is a small tool for Windows computers and Android devices, such as format, bypass FRP, MI cloud, unlock/relock bootloader, and remove Huawei ID accounts. It also supports MTK and Qualcomm devices, as well as Samsung devices in MTP and Download modes.
Features & Functions
– Auto search comports check button: This feature allows you to automatically detect the available comports on your computer and select the appropriate one for your device.
– MTP operations: This feature allows you to perform operations on Samsung devices in MTP mode, such as auto-open YouTube, read MTP info, and bypass FRP.
– Brands with models combobox: This feature allows you to select the brand and model of your device from a drop-down list, making it easier to find the compatible firmware and operations.
– Boot MTK devices with custom EMI / Preloader: This feature allows you to boot MTK devices with a custom EMI or Preloader file, which can help you fix some issues or enable some operations.
– General Method check button: This feature allows you to use a general method to perform operations on MTK devices, such as disabling DM-Verity, crash preloader to brom, and list partitions using custom EMI / Preloader.
– Auto boot with brand & model: This feature allows you to automatically boot Qualcomm devices with the brand and model of your device, which can help you flash the correct firmware and perform other operations.
– Auto-detect storage type: This feature allows you to automatically detect the storage type of your Qualcomm device, such as eMMC or UFS, which can affect the flashing and backup process.
– Reboot after flash check button: This feature allows you to reboot your Qualcomm device after flashing, which can help you avoid some errors or issues.
– Backup OEMinfo & Reset Huawei ID: This feature allows you to back up the OEMinfo partition of your Huawei device, which contains important information such as IMEI, serial number, and region. You can also reset the Huawei ID account of your device, which can help you bypass some locks or restrictions.
– Restore OEMinfo: This feature allows you to restore the OEMinfo partition of your Huawei device, which can help you fix some issues or restore some functions.
– Select firmware files from folder OneClick: This feature allows you to select the firmware files of your Samsung device from a folder with one click, which can save you time and hassle.
– Remove carrier apps: This feature allows you to remove the carrier apps of your Samsung device, such as Verizon, Sprint, T-Mobile, and AT&T apps, which can free up some space and improve performance.
– Read Info (Download Mode): This feature allows you to read the basic information of your Samsung device in Download mode, such as model, firmware version, CSC, and security patch level.
Updates & Changelog
MTK:
Improve some MTK operations Enhance various MTK operations for improved functionality.
Xiaomi Operations:
Add Mi Fastboot to EDL Introduce the ability to switch from Mi Fastboot mode to EDL mode.
Add Mi Enable Diag (Without Root) Provide a method to enable Diag mode on Mi devices without rooting.
Improve Mi Disable Mi Cloud (ADB) Enhance the process of disabling Mi Cloud on Mi devices using ADB.
Server Connection:
Improve server connection Enhance the connection to servers for smoother operation.
Note:
This update will be the final update of Marvel-Tool. Marvel Tool V 7.2 is announced as the final update, encouraging users to anticipate Marvel Tool Pro V8.0 for future enhancements and features.
Setup Password: Marvel-Team
Download Links:
para sa walang smart card, download lang po ito at install
