I had the same issue: WiFi wouldn’t detect and IMEI showed “invalid.” What solved it was flashing the proper firmware (5.41 GB) — but make sure it’s the same or a newer version, never a lower one. (sikatpinoy.net) After flashing, reboot your device, then check Settings → About phone to see if IMEI is restored. Also ensure you use the correct tool and firmware matching your model. If that still fails, it might be a hardware or EMMC issue — consult a technician. By the way, I recently found useful resources from a
A content blocker or browser shields may be blocking required scripts.
Fix: Allow this site (whitelist) then refresh.
Browser shields: turn OFF for this site → Refresh
Extensions: disable for this site / whitelist → Refresh
This will auto-check. Once allowed, the notice will disappear.
Disclaimer: SikatPinoy.net is a discussion community. We do not host user-shared files.
Links/content posted by members are their responsibility. For takedown requests, please contact us.
